1 - 2 of 2 Posts
So i was looking at my master cyl and its gross.. now rebuild kits are like 40 bucks. but i like the small round look of the new style guys. should i look for a whole shabang on ebay. like lever and all or are most levers assemblies the same? i.e use the same type of tensioner,same OD mounting hole (that bolt goes through ) same thickness ??? anyone have any neat articles or threads for swapping lever sets and masters?this is for a GS 450 maybe same i dont know.. thanks
http://www.driftalliance.com
I would look for the entire thing on ebay or in your local craigslist. One from a newer bike will I am sure work however you will probably have to change the way that your brake light switch is hooked up. Lever assemblies are usually different.
You can use a master from almost any Japanese bike as long as it provides a sufficient volume of fluid to your caliper and the banjo fitting is the same size as your existing brake line
1 - 2 of 2 Posts
