Need help on wiring ... it has 4 pins adjacent to a 5 pin ...
Thanks for that. I do have the wiring schematics for both too. Alterntor? Maybe I just don't know how to read the wiring diagram but I dnt see any wires commin from it. NT600 is a vtwin and do you think it would make an inline fire up?I like electricity and speak wiring schematic but I would need to start with a wiring schematic of the original bike and the donor bike too.
I looked at the honda cbx750 rc 17 wiring and the 5 wire connector is coming from your alternator
the 4 wire connector is coming from the pulse generators to the CDI on both bikes and those might be close enough in concept to work, but I would check the service manuals for both those machines and see if the ignition coil resistance is the same. Wiring diagram implies it's the same part, so I'm optimistic it will work.
I think you were looking at the regulator rectifier. 3 yellows and 2 wires black and white from the field coil. Cdi got 9 pins. Schematic says 4pins and 6pins goes in out the cdi.I like electricity and speak wiring schematic but I would need to start with a wiring schematic of the original bike and the donor bike too.
Because he is using 'number of pins' to describe connections that can only relate to the charging circuit. That has little to do with the ignition circuit which is the CDI part.TR why do you keep talking about the charging circuit? He only asked about the CDI/ ignition circuit (which you also touched on).
I don’t see where you got that. The charging circuit you posted has a 6 pin and 4 pin connector. Not a 5 pin. But I see no 5 pin connector anywhere, so I don’t know how you jumped to that conclusion.Because he is using 'number of pins' to describe connections that can only relate to the charging circuit. That has little to do with the ignition circuit which is the CDI part.
Where did I get 5 pin connector from -> his first post:I don’t see where you got that. The charging circuit you posted has a 6 pin and 4 pin connector. Not a 5 pin. But I see no 5 pin connector anywhere, so I don’t know how you jumped to that conclusion.
8Ball you see no 5 pin connector anywhere? -> then you are not looking at the wires coming out of the alternator in the diagram I posted. There are 5 wires required in the alternator connector and that part is also indicated as a 6 P connector on the drawing.Need help on wiring ... it has 4 pins adjacent to a 5 pin ...
That would be a huge fail, rev limiters work by curbing the fuel supply, not by removing the ignition. Thus has it always been. Your plan to remove the spark at maximum revs under WOT would pump raw fuel into your exhaust system, nobody does that or at least not successfully, it would either melt down or explode.... the spark unit determines the rev limit. ...
I’m curious how you think that was accomplished on these carbureted bikes?That would be a huge fail, rev limiters work by curbing the fuel supply, not by removing the ignition. Thus has it always been..
