1 - 7 of 7 Posts
Hello. I am new to this site. I have loved cafe bikes for years and I finally got a bike worthy of being turned into a cafe racer. I just bought a Honda CB500 that some tard put some extended forks on. Does anyone know where I could get some stock length forks? Also I need the whole front brake master cylinder setup. There is no lever, no cylinder, no nuthin. Does anyone sell this as a complete set or will I need to figure out the individual parts and try to find them. I am new to motorcycles in general and specifically old Hondas so any help, links, advice, or anything else is greatly appreciated.
Edited by - 71 CB500 on Feb 16 2006 01:24:30 AM
· Premium Member
Choppers Rule! Leave it the way it is!
Just kidding. If no one on the board has any of this stuff, try ebay. You'll be able to find everything you need. Forks from a 500 or 550 will be the same. Brake master cylinders/levers can also be had from cb350, 360, 400, 450, 750. Pretty sure they're all the same. Also look for the master cylinder rebuild kit. Often a used MC will leak.
Good luck
JD
Hey looks like a nice score and very complete would make a nice cafe bike.
Like JD said E-bay is your friend for stuff like this
what did you give for that bike ?
good luck with your project
84 FJ110
77 CB50 Cafe bike now
76 parts bike
74 Suzuki t500 soon to be on the road
· Premium Member
Install some clip'on bars so you can slide the forks up in the trees about 12"....as a bonus you'll have two good places to hang a helmet.
When you get a stock front end. Put a 1" spacer above the fork spring and change the fork oil to 20wt.... you'll be glad you did. Makes them behave so much nicer.
Thanks for the info. Im glad that I can use the forks off of a 500 or a 550 and the master cylinder from a 750. It seems like there are a lot more parts around for the cb750 so parts interchangability is a good thing. I paid 750.00 for the bike. It seems like a great deal to me.
yah, not too bad. its defnitely clean. and if the pipes are good, theyre worth it. i have a buddy looking for a tnak and seat if you come across one. a clean setup. your bike should be a looker when yer done. if you pull the pipes and want to sell em, and theyre not totally shot, drop me a note.
1 - 7 of 7 Posts
