1 - 2 of 2 Posts
I am rebuilding a 73 CB500 Four and am hoping to wrap this project up shortly. I have resleeved the jugs, put on the bigger pistons, cleaned everything, and painted the head. Everything is ready to be put back together except I need new cylinder studs. As far as I can tell no more exist and I've been looking for well over a month now. I was wondering if anybody happened to know sometihng that would work as a replacement so I wouldn't have to go match these up myself.
Have you actually tried the honda dealer?
rear stud part number is: 90033-323-000
front stud part number is: 90034-323-000
you will need 6 of each. Hondaparts-direct.com lists them for $3.23 for the rear and $4.05 for the front.
If you can't get them that way, try calling ARP fastners. They do studs for a variety of automotive and motorcycle applications and you can usually just call them tell them the size you need and they may actually have them in stock.
Also try contacting APE as they still do a decent amount of honda motor work.
1 - 2 of 2 Posts
