Kinda like when you blow a main fuse?
Thats what I’m thinking, I’m not to sure where it would be though, I’m going to look in the manual and then check out the spider nest of wires in the headlight housing when I have the time.Kinda like when you blow a main fuse?
Fuse box should be behind one of the side panels
All I can say is that runs now and better than ever especially after putting the rs flat slide carbs on itFuse box should be behind one of the side panels
