1 - 20 of 29 Posts
I found a guy selling a 1969 cb350. He says it's complete but it is not running. What is it worth? is it a good project bike? this will be my first bike other than my old bultaco.
That's a great first bike if it's complete! I'd pay $400 for that but you may be able to get it for less than that. Actually picking up a '68 CL350 for $20 which is also complete but been sitting outside.
I bought a 1970 CB350, not running but had been running a couple years ago, for $300. It was complete except for the air cleaners, aftermarket stupid loud mufflers and battery. After fixing a broken wire it started right up, but needs carb work. There also were no papers, but that is not a problem for a pre'72 bike in NY
So, the following check list could give you an idea
Proper paperwork, if registering an old bike is hard in your state-- +$$
Does the motor kick over--not seized--+$$(If siezed plan on at least $800 rebuild)
Are the mufflers original and in good shape--+$$$$ (stock mufflers are VERY hard to find and big bucks)
Inside of the tank rust free-+$$
Does it have the key? +$
IF the motor kicks over, even if it will run, you will most likely need new tires ($100 each), some cables, complete tune up,etc. To me a little tear in a seat is the same as a shredded cover- it needs to be replaced.
A $300 or even a $100 or free motorcycle can very quickly become a $1000 motorcycle!
If the owner will let you, take a compression test. It could be the difference between a buying a bike that needs a top end rebuild or not. If it kicks over and has decent compression, most old hondas will start right up with a fully charged battery, some gas in float bowls and hit the points with a piece of sandpaper. Check that the fuse off the battery is there and not blown, and change the oil before you start it.
Yes it's a great first bike. And you'll find all the advice you need to get it running on this forum. Are you planning on doing a resto project or a cafe' job?
Discussion Starter #5
I am going to give the guy a call in a couple hours. It looks like oil is blown all of the transmission.
I am not going to go all out for now but I will add some cafe touches.
Will I be able to ride 2 up on this with my wife? I am about 155 and she is about 130. We wont be doing much if any highway time like that though.
$1 per cc for a complete non-runner is a decent rule of thumb.
is it titled? if not, $.50 per cc.
Discussion Starter #7
The owner just got back with me and this is what they said:
This is a project bike. It starts, started up yesterday. Needs a battery for the electric start. Only part missing is chain guard. Tires are good condition, but old and need air. Not a bike you'd jump on and ride. Title can be obtained, but not in hand.
I will call the dmv and see what it is going to take to get a title for it.
quote:Originally posted by onesojourner
It looks like the no title thing may be a deal breaker on this. It has not been licensed/titled since 1980.
If the previous owner/seller was the last one to have a title on the bike, he should be able to go to the DMV and get a duplicate title pretty easily:
http://dor.mo.gov/mvdl/motorv/titlerep.htm
If he was not the last titled owner, see if he can direct you to the person that WAS the last titled owner. If not, you may want to get the VIN checked to make sure it's not stolen and then go through a titling service like ITS:
http://www.its-titles.com/
They will cost you $145 so factor that in to your offering price and if the seller is not budging, point out the cost of gaining a new title. Otherwise you're buying a parts bike.....
Jim
Discussion Starter #10
this bike is on its third "trade" right now. The last 3 owners never had titles. That is going back 15 years or more according to this guy. That turns a $350 bike into a $500 bike and I don't know that its worth that.
I'm from Missouri as well and there is another way to obtain the title. You can go to your local judge and he can issue you a title. I've seen it done on several cars and motorcycles that were either abandoned or found on property that was purchased. There is a form you will need to fill out and you will have to have the sherrifs office or MSHP do a VIN check. I see you're in Springfield so the Green County Court House should be able to tell you all you need to know. I have a friend who obtained titles for 11 VW Bugs using this method and they cost him $25 per title. This was in Texas county but I believe it goes for the whole state. Just check with your local court house for the details.
Discussion Starter #12
Wow thanks for the tip. I will call the court house asap on monday. If I can get a title for 25 bones I will buy the bike. That will make it $375. Does that sound like an ok deal?
Discussion Starter #14
Actually it doesn't run. His wife was confused I guess. I did kick it and it feels like it does have decent compression. There was no battery so I couldn't test the starter. I found something on the county site and it looks like it is going to be more like 75-100 bucks - and that's if I can figure out how to write a petition for the the title. I guess I could always just try to low ball him and offer 200 bucks for it.
Administrator
it's a project bike. gonna need some work and finishing.....kinda like your bio.
welcome!
-tex
If it doesn't run & has no title, you may want to pass on it. I bought one non-running complete parts bike w/o title for $22, another running w/o title for $85. "Running" cb350 motors (usually w/o carbs) tend to hover around $100-$150 on eBay, and carbs can get pricey. Torn diaphragms for those carbs, a very common problem, are expensive to replace. I'm not the cb350 expert here, but were it me, I'd pass on this one.
Post pics of the 'Taco.
hey peter. i was gonna refer here you when you said you were looking at a Cb350. this may not be the right bike, but if you do get a 350, this is THE PLACE for all sorts of useful info. goodness me.
welcome.
jarrett
also, what judey said about the bultaco.
Discussion Starter #19
Hey man ms me on fb. we need to get together.
Here are some pics of me riding the alpina last summer. I need to get the skis put up for the winter and get it to my garage to work on it.
I don't want to be Mr. Negative, but am I the only one tired of seeing new members intro featuring pics of them wearing brown shirts? Or jeans & running shoes, for that matter?
(just me & my huge bad-ass, pie-baking ego getting out of hand, running off another newbie)
BTW, thanks for the pics & welcome, new guy.
1 - 20 of 29 Posts
