A few weeks ago I bought a Dyna S ignition for my 75 Cb750 and installed it. After installation and timing I could tell the bike wasn't running right. I used the timing light to check the wires for spark. Cylinders 1-4 are fine. Cylinders 2-3 are both running at idle, but when I rev the bike cylinder 3 cuts out for a second and then comes back, and cylinder 2 completely quits and doesn't start sparking again until idle.
When I first got the bike running (a year ago) cylinder 2 wouldn't run, and then it just started working. A couple months ago I started the bike for a ride and cylinder 2 wouldn't work for about 5 minutes, then it kicked in and ran fine. There has been an off-idle stumble since I got the bike that I couldn't tune out with the carbs, maybe it's been from the 3 cylinder cutting out for that second?
The coil tests fine, and I've checked all connections. Any ideas? I was just going to buy some Dyna coils, but I want to be sure the problem is the coil. Thanks, Jimmy
