1 - 5 of 5 Posts
I'm thinking of plumbing my CB450 with an oil cooler and external head oiler. Dunno if the CB350 is similar, but if you've never taken one apart the oiling system is:
piston pump > spinner/filter > reservoir > main bearings (via restrictor) and head (via passage around one of the cylinder studs)
My plan is to tig a -4 male bung onto the sidecover where the oil reservoir is, and then tig a -4 male bung on each of the cam bearings on the right side of the head.
Oil would go:
pump > spinner > reservoir > oil cooler > head
AND
reservoir > restrictor > main bearings
I have seen other setups that go
pump > spinner > reservoir > oil cooler > reservoir/head
so ALL the oil goes through the cooler before hitting the rest of the engine.
I just have my doubts about the ability of the stock piston pump to flow oil through the cooler to the head reliably.
any ideas?
Discussion Starter · #2 ·
Here's the "full flow" system like my second example:
And here's the "partial flow" system (notice it's a 350 motor):
Edited by - robertob on Feb 01 2008 2:11:39 PM
Thanks - I plan to do an oiling system similar to yours but I want to detour the oil to the top of the engine replacing the factory head oiling system.
But your oil system is almost just like the CB450...
I opened up the oil metering holes at the cylinder bases and in various places in the head to increase oil supply to the head so I wouldn't need external lines. And the main feed to the cylinder head on a 175 is like first in line off the main supply gallery so it's sill pretty cool oil when it gets to the head.
I also opened up all the passage from the pump, to the filter, and out of the filter to the main gallery about 25%. The 175 really doesn't have oiling issues, my main purpose was cooling the head. Now the bike is almost too cold blooded :)
1 - 5 of 5 Posts
