How are you storing it? outdoors? Indoors?quote:
What are some thing I should do before I put my bike away for the winter?
Thanks Gee. Not sure where Im going to store this thing. I had a yard but no garage and Im not sure I want to store it outside over the winter but I have no where to store it inside so its probably my only option.quote:
If it is outdoors, put some stabil in the gas and leave the level as low as possible. The stabil in the fuel will keep the tank from rusting up inside. If you want to go crazy you can put some fuel and two stroke oil in there and swish it around - just make sure you remove that gas before you start it next season. Some prefer to empty the tank - I don't because I figure the stabil or the two stroke oil does a good job at keeping condensation moisture at bay. If you are storing indoors, same thing except you may want to empty the tank.
Plug the exhaust. Ever blow a rat out the pipe in the spring? smells bad and makes your bike run like crap. Hard to clean out too. I usualyl throw a dessicant pack in the pipe (not too far in) and then tape the ends. critters hate the smell of dessicant packs and it keeps the moisture from eating my pipes from inside.
Drain the carbs. The easiest way is to shut the petcock off and run the bike out of gas. This will ensure that it will actually run without a rebuild next spring. Next best thing is gas with stabil in it.
I oil all my rubber parts to keep them from drying out. This is personal preference but it helps when it gets really cold in the garage.
battery tender on the battery - keeps the bat in good order.
That being said I haven't done a lot of this stuff in a while (the stabil I do) because I ride till first snowfall (usually january) so my down time is only three months (jan, feb, march). I still have the speeding ticket I got on december 28th last year (I really have to pay that).
Don;t run your bike unless you intend to ride it. Lots of guys think they should start the bike for a few minutes just to let the juices circulate. This builds condensation in the pipes and causes them to rot from the inside out. Ever seen a garage find bike that was perfect except for the pipes? now you know why. If you feel you must circulate the oil - with the plugs pulled (so you are not fighting compression) kick it over or use the electric starter (much easier). This will spin the motor faster and allow the oil to circulate as if the bike was running.
Would love to but its kind of hard to ride where theres 1 foot of snow outside.quote:
you guys are fucking panzies. take off the skirt and ride it mary!
When I lived in rochester I used to ride in snow. I wore heavy construction boots and kept my feet down the whole time. Wouldn't go further than the grocery and back but still it got me around. A buddy of mine did ice racing and he made is own studded motorcycle snow tires for his /6 beamer.quote:
Damn I'm a real idiot. Yes I did know that the battery comes out, I dont know why I didnt think of that.quote:
you do know batteries come out of bikes don't ya? put the battery someplace out of the way (like the basement) and plug in the charger. The cold will pretty much kill your battery if you leave it outside anyway.
Stabil is designed to be consumed in the engine so leave about 1/2 a tank of gas with stabil in it and when it comes time to start it again just put fresh gas in and run it through. If yo put two stroke oil in the tank then you will want to drain it before running the motor.
Of course you do. You should do everything I say to do. I am always right.quote:
actually, i like pretty much all of robs ideas. i can say ive done at least all of thse at various points.
Hey, what do you expect from a borrowed bike? I probably should fix the front brake before I return it....quote:
branson???
ok, ill get right to work at pushing my dirtbike up a hill for 2 hours first thing in the morning. without the chain attached of course.
