Forks?
Your bike is heavy because everything is steel, replace steel parts with aluminum parts and the bike will be lighter. Your footpegs, centre stand, side stand, fuel tank & rims predominately. The headers will be double walled steel. Your brakes and suspension components are good candidates for replacement. Don't go lower then flat bars or it will be a bear to ride and don't reduce the cornering ground clearance because they can drag hard parts as is.
Carb leaked because it had a stuck or leaking float/needle&seat , might be rubber parts.
