1 - 6 of 6 Posts
it stops and it goes well
decided it will get a heavier DID chain which I have already sprang for
kick lever is bent :-(
Discussion Starter #2
and the chain guard for it is going to be a MFer but I cannot see running it without one being a good idea at all
that little one fails and all hail could break loose
so it will be totally enclosed in stainless tubing except they will be cut away to clear the outside bends of the sprockets
and guess I'll incorporate something light and tubular for the drive chain as well
HackA,
What a Rube Goldberg setup that is. Why not just brake on the left and shift on the right? Its not so tough.
Discussion Starter #4
well the foot clutch is on the left and the shifter is via hand.......... that lever you see in the first picture
robbed off a surgical tool used for splitting sternums
doubt Rube would want any part of riding this suicide machine
anyhow...... at one time it was setup with the brake and drive chain on the same side
7 inch drum stamped steel thinner than 0.100"
shoes 7/8" wide and would fade to nim before it slowed the bike down from 90
couldn't handle the power either since it let go of the riveted sprocket three times
only sprocket choice was 41T
needed a cush drive, and an actual working brake on the rear, when it got the belt
sprocket changes on that wheel are very easy and I can go as small as 22T
make more sense now?
Discussion Starter #5
oh, and the other objective is that any of this stuff will bolt directly onto any of my other flatties without modification to any of their stock frames
the only exception to that are the two tabs welded to the seat post which serves as an anchor and pivot point for the dual air chamber seat shock
so had to work with the holes that exist for everything fabbed up for it
a good question is why not cable it from the midship
well there is a good reason why that wasn't a good idea within the bolt on objective or I would had and it would have been much simpler to do
Makes some sense, except why do you need any stinkin brakes anyhow? Just pitch it in to the turn and hope for the best.
1 - 6 of 6 Posts
