1 - 1 of 1 Posts
Well the Daytona used a CDI ingition setup which rocked compared to the points. I'll look tonight and see what the numbers are on the battery. You should be running a 12 volt battery for that beast. The RD's won't run worth a crap with a low battery in them. A 6volt charger won't be able to get you the needed current you need. Start with a fresh battery, and let it charge and go from there. You may have other issues but start there. You can email me at [email protected] if you need more help.
Matt
1 - 1 of 1 Posts
