1 - 6 of 6 Posts
1979 XS750
On to the seat job, my wife is gonna try and do the stitching after I form the seat foam. Gonna do more of a thinner stock style seat. It’s on the original metal seat pan so it’ll need rivets right? When I do the rivets do I just go from the outside in through the vinyl on both sides keeping the rivet head exposed? Or can I “hide“ the rivet Somehow behind the vinyl?
105274
105275
Letting the glue dry for now (y)
You could likely drill the rim of the pan and use a pinch strap on the underside to hold the vinyl. Use appropriate binding post and they won't be noticeable under the seat cover. How was it attached from the factory? Post a couple pictures of the pan.
These are just an example.
1979 XS750
Automotive tire Automotive exterior Bumper Composite material Tints and shades
Tire Motor vehicle Automotive tire Tread Automotive lighting
the factory was riveted somehow under the foam while staying behind the vinyl. It’s like the backside of the rivet was exposed Under the seat But hidden on the outside. I like the pinch strap idea...
The holes are there. I wouldn't bother with the strap, if they are evenly spaced around the perimeter, just use binding posts. Take the pan to a fastener shop and you can get the right dia/length.
Don't cut the holes in the vinyl use a paper hole punch. A clean circle won't tend to tear.
1979 XS750
You da man (y) :cool:
It might take a while to get the vinyl stiched up but I’ll report back with the finished product. Those binding posts are just what I had in mind, just didn’t know they existed haha
1 - 6 of 6 Posts
