I have a 75 CB750k. The front break was stuck when i got it. I took it apart and it was very dirty. I flushed the fluid and lots of crud came out. Once I put it back together it worked 100% better but it still doesn't feel right. When i engage the brake it works but then sticks a little after it is disengaged.
How does the piston return to the off position? I did not take the piston out when I took it apart. I only cleaned the caliper and the small disk between the caliper and the piston.
Should I take the piston out or is it not meant to come apart?
Thanks, Again.
P.S. is it possible to post too many questions on this forum. My wife is giving me a hard time.
Thanks, Again.
