1 - 10 of 10 Posts
I'm looking for a lower wattage headlamp for my CB350F. Most I see are 55 or 60 watts. I'd like to find something lower - hoping it will be less of a drain on my electrical system. Didn't alot of the old Brit bikes use a 35 watt lamp?
Any direction would be appreciated.
1974 CB350F
1965 Lambretta Li150
2003 Stella
I think some companies now are even making LED headlamps. Or even make your own http://www.instructables.com/id/DIY-LED-car-headlights!/
I gotta build a LED bulb for my SL70...the OEM bulb will drain a fully charged battery dead in about 20 seconds and takes about 10,000 rpm to make usable light.
Hmmm... I better check it and make sure it's not a 12v bulb in a 6v system.
what's wrong with changing out your signals and taillight for LEDs?
You're assuming I have and/or use turn signals. <img src=icon_smile_big.gif border=0 align=middle>
I've already switched out the 1157 tail light for a 1030(?) which draws less power. I've got a Luxeon on order which should only draw about 3 watts.
The headlight is, by far, the biggest draw though.
So...anyone know where I can get a 7 inch, 35 or 40 watt bulb?
1974 CB350F
2003 Stella
Try www.candlepower.com
Use the numerical listing, there is a guide at the bottom of the page that you can use to identify the base and glass size, then scroll through till you find the wattage you need.
FR
Discussion Starter · #7 ·
On a related note, I was wondering about the possibility of mounting a Brit style headlight bucket (with the voltage meter) on my CB350 project. Even if I didn't hook up the voltage meter, I think it would look cool. Would it be possible to hook it up? Would it produce a drain on the system?
1974 CB350F
2003 Stella
wires is wires...you probably could get it hooked up and working no problem. As for the brit headlight shell, why not? I use CEV and hodaka headlights with integrated speedos all the time, you will need aftermarket headlight mounts but headlights always come down to mounting with a bolt.
i bought this light 130mm cev from cosmo for about $35 without a lens or bulb which was lower than his auctions usually go. the mini speedos and tachs you see everywhere fit perfectly in the recess. i also bought one on another site with lens for $28 for another bike it doesn't have the switch on the top or the indicator lights on it. no picts cause i'm still waiting for it to arrive.
...connoisseur of slack...
Sweet!
1974 CB350F
2003 Stella
1 - 10 of 10 Posts
