1 - 5 of 5 Posts
i have a 1972 cb750 and i need two new handle bar switces! i cannot find them on ebay for the life of me for the 72? will any year model work? like say the late sevenies or early eighties? or does anyone know of a site where i can buy after market ones?
thanks
You need to be careful of stop switches, some, for later models are 'grounding' switches and send trigger signal to ground.
You can use them but they may need to be in 'Off' position to work plus the green wire will go into Black with white tracer
You need a closed 'On' open 'Off'
Discussion Starter #3
ok thanks for the advice! do you know of a good site where i can get after market switches? i can't find any for that year on ebay or am i better off just looking around on craigslist?
thanks
I'm sure there are aftermarket copies of Honda switches, they fitted them to 350, 450, 500f and 750.
The switch bodies are pretty much all the same, as is the wiring. The connectors on the ends may possibly be different but will still work as Honda use 3.5mm and aftermarket is usually 4mm
You could get some bullet connectors and a crimper to swap them if you need to, couple of places do them (get the correct crimper though, they look and work better than the 'crush' type)
careful of some of the 'hong kong' sellers out there selling 'NOS' honda switches for the 30-40$ range. Pieces are okay, not great, casting and holes barely match up and they're missing pretty much all the markings of an actual OEM switch. an okay replacement, but better can be had.
seems to be a lot of crap selling on ebay as 'genuine oem NOS'...but I think for a majority of them the only thing genuine is the bag and part number
1 - 5 of 5 Posts
