1 - 10 of 10 Posts
I'm trying to come up with something for my FCB, since the one that was on there was busted off I'm having trouble visualising possible mounting solutions. If you have / can take a photo of yours and send it to me it would be much appreciated.
Thanks
J "not that" D
· Premium Member
j not that,
check your email. pics are there of my bike and setup.
p.s.- bike was in corner and i was too lazy to move it. will be moving it on friday when i load it into van. it has been there since unloading after frontierland. i am the laziest!
· Premium Member
sweet pants,
yeah, first row, down towards the end, right of pit out if you are facing the front straight..........
or the same place i was last year.
p.s.- bring gatorade!
not that-
what i did was use one of the fork clamps that are usually sold with the dampers but instead of the fork tube, i mounted it to the frame downtube (35mm i think, maybe bigger) to attach to the damper to the frame, then i used the threaded hole that seems to be on all CB lower triple trees to mount to the damper to the forks.
hope this helps, but not too much.
best. tt
1 - 10 of 10 Posts
