1 - 6 of 6 Posts
Hi folks, I am looking for a used or new Supertrapp muffler (that I can adjust with discs). And who is the vendor I can talk with? I have a 2 into one header (Jardine?). I ran the bike in the FCB350 with USCRA. I know the exhaust is not really working like it could. My friend Killer Baker said it was my body weight and talent that are holding me back. But I think if I was running his homemade (weird and questionably loud) exhaust, I could do much better, maybe beat him on his old age. But he won't share any secrets, legal or not. So which Supertrapp would be best on a 2 into 1 header for stock CB350? I don't want to spend more on the pipes than I spent on the bike. FFS. Thanks!
I had a CB350F with a 2 into one Jardine it was nice! Exhaust isn't the way to beat him, there are tons of speed improvements that can be done on those bikes.
Discussion Starter #3
Thanks, when I think about it, you are correct. My pipes have actually been pretty good. It's hard to stay stock with the CB350 and have extra power...but I can work on making everything balanced and tight with the motor, and work on track practice.
What do you have in it for steering head bearings and are you still riding on steel rims, the stock brakes were **** suspension components were crap. But omg did ever sound sweet at 13000 rpm
I had a full fairing on mine that I made out of a TZ350 fairing, not the easiest fairing to fit, worked good but not easy to mount and I couldn't keep the belly pan, you need that to race now.
Fit wider alloy rims (WM3 front and rear) The original rims are heavy (WM2 front is nearly 6lbs compared to less than 4,
It will also handle a lot better
Alloy wheel spacers save another pound or more, ditch starter and all reduction gears, firt small battery and you save at least 10 lbs
I have the actual numbers but I can't find them at present
1 - 6 of 6 Posts
