Ok, the CB450 cafe racer bike...
Put the 32mm carbs on it. Using a Motion Pro cable.
Here's the problem: I can't use the stock throttle housing because it won't pull the cable far enough to open the carbs all the way. If I use the MotionPro throttle, I get full carb opening, but I need to move the killswitch and high/low/off headlight switch off the handlebar.
Other than getting some marine quality switches to mount somewhere betweent the tach/speedo, what can I do? Its nice to have the headlight switch reachable by thumb. Ideas?
