New bike came with tubeless-ready wheels and tyres (Schwalbe Pro One), but with tubes fitted.
First puncture was rear wheel and I did the roadside fix without major issues, replacing the tube.
Front-wheel went flat recently, fortunately overnight, so I wasn't stranded. I had major trouble getting the tyre off, and resorted to standing it on a radiator for half an hour to soften everything.
I have totally failed to replace the tube. The tyre is too tight for me to get it back on without resorting to tyre levers. Yes, I know this is not recommended, but I sometimes resort to gentle levering with my other bike. This time, an impossible job, I cut two inner tubes trying to get the tyre back on. Please note, in 40 years of cycling, this is the first time I have damaged a tube when installing it.
The tyre is so tight, I can't stuff the tube properly into the tyre casing.
After some thought, I concluded:
1. the tyre and wheel are designed to be run tubeless, so it is meant to be tight.
2. I can't risk riding the bike with a tube setup, as I can't fix a flat.
3. Choice is to go tubeless or buy regular tyres e.g. Gatorskins that I can handle.
Any thoughts or experiences to share? Will a DT Swiss E1800 spline take a regular tyre, or is the rim design always going to be a problem for tyre fitting?
