1 - 8 of 8 Posts
Whats up to all the great Cafe Racers on this site!!!
I need a little advice. I recently coated my fiberglass tank
with a sealant to protect it from pump gasoline.
Part of the process was to clean out the inside with paint
thinner/acetone. I acidentally spilled a little on the exterior.
So I now have some dulled paint. Its not too deep into the clear
coat and I am sure I can get the original gloss back.
What do you think I should do to get it shining again?
Should I just wax it?
Which product should I buy for this job?
Thanks
It depends if you have a clear coat or not on your tank and how thick it is. If you have a clear coat, you can hit it with a little 2000 sand paper and buff it out with a chemical polish. You may want to try the chemical polish first and see how that goes. I don't think regular wax will do anything for you - may be a cleaner was.
If it's just paint - I'd still try the cleaner was but the results may not be the same as the remaining paint on the tank..
Bob, I have a thick clear cooat on this bad boy.
Its like candy.
Without sanding, what product can I buy at the automotive store that will bring it back to life?
You can try a tought rubbing compound possibly. If it works then use a finer compound until it's glossy again. i'd probably go by one of your local body shops and get an opinion..
Jerry - if your a little timid about working on the tank, stop by any auto body shop and they can re-buff the tank for you for small dollars.
Discussion Starter · #7 ·
Bob, I bought rubing compond at the auto store. Works great but looks a little dull. At this poing a little wax job will bring her back to normal.
Thanks for the advice!
wetsand the tank with 1000 grit (yes one thousand) sandpaper and lots of water. Then cut it with a pro-grade polishing compound and a rotary wheel with soft foam pad. will look like new.
1 - 8 of 8 Posts
