1 - 8 of 8 Posts
jd-
yeah, same questions. what's the story with race gas. with stock compression and only 38-40° full-advanced timing, does it make a difference? i'm sure with increased compression and crazy timing, it would make a difference....but what are the benefits to a stocker. temp changes? colder plugs? i have no clues.
by the way, the electronic ignition didn't make a real difference by itself, but did allow me to focus all my attention on the carbs. turns out i was rich, but only on one side (i'm guessing because of the 4 inch gash i put into my left header on turn 6 that restricts the diameter by about 1/4) so with two different jet set-ups on the twin, now i can finally make a few rpms in the first few hundred yards. i can also back off the throttle without losing what litte power i was making, not that i want to back off the gas, but maybe i'll be less of a hazard with a bike that can actually run outside of the redline.
· Premium Member
I run VP-C12 in our race bikes...both have somewhat higher than stock compression and some pretty radical timing (45-47 BTDC fixed).
Actual compression on stock engines is around 8:1 regardless of what the manuals say. Our race engines are probably in the area of 9.5-9.75:1. So...we don't need the octane of C12 but I like the way it behaves in the bike. It's more forgiving of small jetting errors, it runs more consistantly throughout a race...even when the engine gets very hot. It seems tolerant of just about any weather/atmospheric conditions.
Downside is heavy exhaust valve deposits and it doesn't like to be used if you are just going to putt around. It performs at it's best when you are running the engine very hard. I'm thinking of mixing with some U4 to try to lessen the valve deposits. It's serious race fuel meant for engines that they figure will get torn down pretty often so to them valve deposits are no big deal, as they will be removed every race or two.
I've also used the NHIS track fuel for numerous bikes both almost stock and heavily modified...seems to work decent.
· Premium Member
That's kinda what I was hoping...that mixing with standard race fuel would clear up some of the deposits. But...fuel mixing is strange, and not intuitive...you never know what you'll end up with.
I'd think on a stock engine the best bet would be the trackside fuel. It's leaded, around 108 octane I think. The higher octane may cost you a tiny bit of power, but typically the other additives will help keep the engine alive.
· Premium Member
JD,
Don't get me wrong...C12 is not going to hurt a stock engine. And might go a ways to protecting the top end. The valve deposits don't become a problem until after a few races...even then it will depend...every engine is a bit different. And by "problem" I mean reducing exhaust gas flow maybe 10-15%....I'm guessing a stock engine has exhaust flow to spare in the port.
Don't worry about it, use it...and you don't have to worry about having decent fuel in the bike, you'll know you have some of the best.
1 - 8 of 8 Posts
