1 - 11 of 11 Posts
When I put together my bike 4 or 5 years ago, I used whatever fuel lines I found lying around so there's some oem pieces, some auto parts store pieces and some lawnmower parts.
I'm looking replace the lines and valves from the petcock to the triumph 900 keihin carbs. I think the carb lines are 5/16". tank lines off the petcock of the xs750 tank I think is 5.5mm(?).
What is your go to fuel line especially with this darn ethanol blend fuel these days?
I'm looking at this but looking to see what you pros are using.
Discussion Starter · #2 ·
Anyone using modern fuel injection quick disconnects on their carb'd bikes for quick tank removal?
The plastic valves I've used cracked when I pulled the hose off. Not very reassuring...
Do you have the space for them? Earls, if they make a style that would work, would be handy to have.
I've used this fuel line a few times. I fitted it to my NTV 2 years ago with no issues as yet.
Shame that I can't say the same about the fuel pump.
  • Like
Reactions: jcw
better to use non-fuel injection hose as the pressure is no more than 6psi. hi pressure hose is way less bendable and way more heavy duty than needed.
It has carburetors, better to use gravity, but the style department and the engine design department sometimes don't see eye to eye on things, so you need a fuel pump and all the problems that brings with it, including the occasional motorcycle bursting into flames when the open air fuel pump starts bleeding internally.
1 - 11 of 11 Posts
