1 - 3 of 3 Posts
I want to put some comstar wheels on my cb500t. I have a front comstar from a cx500 and want to buy a rear comstar from a cb750f because it is an 18" with a disk brake. Will this work?
Thank You!
You may need different spacers but I don't see why not....
See if your axle size matches via the below link. Then, you need to know if the brake disc thickness and offset match up with your caliper. I have no idea if that will work on the stock forks.
someone else here had a cb450/500t with comstars on them, search the last 3 pages or so for it, see what he did.
Axle and Bearing sizes
1 - 3 of 3 Posts
