1 - 6 of 6 Posts
Hello,
New here and just picked up a "new" 78 xs400. Anyway, the bike starts runs and idles fine once warm. However starting it is the biggest pain ever when cold, and once its started I cant get it to idle well. It is very slow when cold, Id say around 600-700 rpm at best, and you need to crank the thing forever. Using even half choke seems to only flood the engine. As I unerstand if the bike is hot, using the choke should increase engine speed, on my bike even half choke just stalls the motor. I have the haynes manual for the bike but it says that the carbs arent to be tampered with, therefore is rather useless. I know nothing about these carbs, and therefore any help would be appreciated. I am not familiar where all the adjustment screws are and dont want to further make problems for myself. They are mikuni bs34 units.
Thanks.
Check the float needles and seats, sounds like a carb problem. Also check the fuel tap if it's a vacuum operated one. Does it do the same thing if you turn it to "prime" (does it have a prime setting?)
Anyway putting on the choke when its hot will usually flood a motor out after a bit.
Seems like a Yamaha (or an old bike in general) problem.
My 83 XJ650 has the same problem... Same carbs (4 vs. 2)?
I'll be rebuilding the carbs this winter - for now she's stripped down for paint.
Post here again when you figure out the problem.
1 - 6 of 6 Posts
