1 - 5 of 5 Posts
I tried to re build my 79 Yamaha sr500 carb which came with a stock mikuni vm34ss carb and just when I thought I had it about finished. I found that I have an extra part. I cant find it in a single diagram and when I take apart my identical mikuni carb, I cannot locate it. Can anyone help tell me what this part is or where it goes?? Your help is greatly appreciated!
Unless the hole for your low speed adjustment screw was plugged to prevent adjustment, I think you maybe found a part that does not belong to the thing you took apart. I've done that before.
Banned
Have a look at your slide linkage again.
If its anything it looks like number 39 in the attached pic. Therr are two parts that sit either side of a ball joint for the internal slide linkage.
I could be completely wrong and speaking out of my arse but thats the only thing in your carb that i think looks like that
Give us some dimensions too as its hard to tell scale from the picture.
1 - 5 of 5 Posts
